Hi,We are trying to connect a third party application (SaaS) called Lincros as a new connection in a O2C project.What would be the best practice to establish a connection for it?
  • Nov 30, 2023 9:54 AM UTC
  • 121 views
itay.tarab
Level 3
Hi, We are trying to connect a third party application (SaaS) called Lincros as a new connection in a O2C project. What would be the best practice to establish a connection for it?
itay.tarab
Level 3
  • Level 3
  • Dec 3, 2023 7:56 AM UTC
Any help?
  • Level 0
  • Dec 7, 2023 12:20 PM UTC
Dear Itay,
Thank you for reaching out to us.
To be able to assist you further, we would suggest sending an email to servicedesk@celonis.com with a detailed description.
We will gladly try to help you
We are always here to help you.
Thank you in advance.
Regards,
