Hi Team,I have Two Data Pools, Data Pool 1 & Data Pool 2.Now, i want to merge / add Data Pool 2 into Data pool 1. Data Pool 1: Transformations are having extra logic compared to Data pool 2.Tables used in Data Model are same for both pools.
  • Sep 14, 2023 5:29 AM UTC
  • 83 views
Hi Team, I have Two Data Pools, Data Pool 1 & Data Pool 2. Now, i want to merge / add Data Pool 2 into Data pool 1. Data Pool 1: Transformations are having extra logic compared to Data pool 2. Tables used in Data Model are same for both pools.
muthappan.alaga
Level 8
you can copy the data jobs from Data pool 2 to data pool 1. Transformations level it is not possible. Once you copy the data job you can make the transformation tasks as template and copy it to use it to the data jobs wherever you need in data pool 1.
