Hi Team,I am trying to export my data from datamodel to dataframe in the ML Workbench.
  • Feb 19, 2024 8:27 AM UTC
  • 5 replies
  • 144 views
kandi.naidu
Level 7
I'm getting this PyCelonisPermissionError. Even though I provided all permissions to user key
Please find the attachment,
Sverre Klein
Forum|alt.badge.img+13
HI @kandi.naidu,
Check if you have permissions on the "Data Pool" level if you may Manage the data pool. This solved a similar problem I had as well.
Sverre Klein
kandi.naidu
Level 7
  • Level 7
  • Feb 19, 2024 8:52 AM UTC
Hi @sverre.klein11 ,
I already provided permissions in datapool,machine learning, studio etc.
But still getting PycelonisPermissionError.
Forum|alt.badge.img+28
Hi @kandi.naidu,
If you are sure that the User or API key you are using has the right permissions, it could be that your environment doesn't allow you to push data via the API. This is even more likely since you are running a C4C environment, where this could be the case.
kandi.naidu
Level 7
  • Level 7
  • Feb 20, 2024 1:33 PM UTC
Hi @kandi.naidu,
Hi @janpeter.van.d ,
Is C4C environment doesn't allow push data via API ?
It should not be like that right ?.
Can you show me where I can see rights for the environments?.
For Discovery projects in the old C4C program, data upload was not allowed, only file upload.
Since this is a setting in the back-end, I would create a support ticket to check this.
