Hi Team, Do we have an Variable Input Component in Views?
  • Feb 12, 2023 2:52 PM UTC
  • 6 replies
  • 141 views
I wanted to create a KPI with reference to Variable <%= Discount %> (Users could define their Discount value). For example KPI as Actual Sales:
(KPI (Sales)- KPI(Sales)* <%= Discount %>)).
I'm able to create it in Analysis by defining Variable and adding the VARIABLE INPUT (Users may add their discounted values) Component however not in Views.
  • Feb 13, 2023 11:00 AM UTC
You can try use Input Box component and 'onChange' function for that.
Variable will be updated automatically.
imageInput Box (celonis.com)
Regards
  • Feb 13, 2023 1:36 PM UTC
Regards
Agreed, don't forget to define the variable:
metadata: ...
variable:
- id: id-of-the-variable
defaultValue: myDefault
  • Feb 14, 2023 4:26 PM UTC
Regards
Hello Marcin,
I tried above mentioned approach, however the variable is not changing dynamically. Could you please suggest what I'm missing below ?
Steps I followed:
  1. Defined Variable under KM with default value 10
image2. Calling that variable in input-box.
imageAs you can see below, if I change the variable to 20, the Sales * my_var column is not updating it stays as default value i.e. Sales * default value 10
  • Feb 16, 2023 5:48 PM UTC
Hello Marcin,
Steps I followed:
@marcin.szcze12 @hanna.franz Could you please let me know what I'm missing in above steps ?
  • Feb 20, 2023 7:29 AM UTC
Hello Marcin,
Steps I followed:
@gundappa.s11 Sorry for replying so late, if you still have problems with changing variable could you please share printscreens once again as I can not see them?
  • Feb 20, 2023 8:06 AM UTC
Hello Marcin,
Steps I followed:
@marcin.szcze12 Please find the below printscreens for your reference.
