Hi Team, Anyone worked on Apache Kafka data connection, if so please provide relevant documentation and steps how to extract tables from it.
  • Mar 6, 2024 5:39 AM UTC
  • 5 replies
  • 254 views
kandi.naidu
Level 7
Best answer by prateek.sharm14
I would recommend to read stating the below link, and read how the whole kafka data pipeline works.
https://docs.celonis.com/en/kafka-to-celonis-platform-connector.html
If more queries, you can reach out to your Celonis accounts executive or partner executive.
prateek.sharm14
Level 3
Hi Kandi,
I'm a Celonis customer who has worked with Celonis kafka connector. So my response is from customer perspective.
Kafka is not really a table. It's a messaging flow that stores data for time duration or data size defined.
I would recommend to first go through an overview of how kafka works, and what's kafka connect. These are prerequisites to better understand the solution.
Below is a link for kafka connector. Please contact your Celonis contact for support specific to your scenario.
https://www.celonis.com/ems/platform/real-time-data-ingestion/kafka-connector/
kandi.naidu
Level 7
  • Level 7
  • Mar 6, 2024 6:03 AM UTC
Hi @Prateek Sharma ,
I go through the link provided. Can I know how I can see the table in the data integration. Can you share me some screenshots to understand little more.
prateek.sharm14
Level 3
kandi.naidu
Level 7
  • Level 7
  • Mar 6, 2024 6:18 AM UTC
Thanks @Prateek Sharma  for valuable information.
RPaul
Level 1
  • Level 1
  • Aug 13, 2026 7:03 AM UTC
can you please share the updated link… this link doesn’t work now, but we do have a requirement.
