Hi, is there a way to see/use autogenerated KPI in the View?
  • Aug 13, 2024 3:31 PM UTC
  • 261 views
rita.kiss12
Level 7
Forum|alt.badge.img+3
  • Level 7
  • Aug 14, 2024 7:39 AM UTC
Hi Huseyin, a bit more information would be helpful to answer your question.
What do you mean autogenerated KPI?
In the Knowledge Model, there are some autogenerated KPIs. And, I want to use them in the View Asset but I could not see them while trying to create KPIs.
Vladimir.Puskaric
Level 6
Hi everyone,
is there an anwer to the above question? I have the same isssue:
When configuring a new component in a View, for example a KPI list, auto-generated KPIs in the Knowledge Model do not come up in the list of Metrics.
I look forward to  a response. Thanks.
Vladimir
abhishek.chatu14
Auto-generated KPIs are not visible in the Views. As a workaround, you can copy the KPI ID and reference it in the frontend using KPI("ID"). If the KPI is required frequently, it is recommended to create a dedicated KPI instead.
