Hi,Is there a way to filter documents based on textual values across both models simultaneously, despite the lack of connection between the tables?
  • Sep 24, 2023 9:14 PM UTC
  • 83 views
wojciech.brol
Level 3
In Celonis Studio, I have two different data models: one for AP (Accounts Payable) and another for P2P (Procure-to-Pay). I would like to create a filter on the view that allows me to display documents that have been paid on time or paid late.
When I try to apply the filter for the AP model, I receive a message indicating a lack of connection with the corresponding table in the P2P model. My goal is to create a filter that, upon detecting the "paid on time" or "paid late" status in the AP model, will automatically display the documents corresponding to that status in the P2P model.
abhishek.chatu14
Unless you have created a connection between the two the same is not possible.
