Hi, I would like to set up a connection with an Azure data lake consisting of same parquet files. Does anyone know which data connection to make and with which settings?
  • Feb 17, 2023 12:20 PM UTC
  • 5 replies
  • 151 views
HI @femke.van.d
Please be informed that this can be done via Database JDBC connection. For more information please check our online help documentation: https://docs.celonis.com/en/database--jdbc--connection.html
  • Mar 3, 2023 9:48 AM UTC
Hi Doruntina,
Thanks for your answer.
I already found this documentation, but I can't find how to use this JDBC connection on Azure Data Lakes. What configuration do I need? And is it even possible to connect with just "parquet files" or do I need a Database (or something similar)?
Femke
Hi @femke.van.d
Could you please reach us out via servicedesk@celonis.com and include the details needed and we will advice you further?
Thanks in advance.
denis.bu
Level 2
  • Level 2
  • Jun 7, 2024 11:17 AM UTC
Any news on this subject? It appears that there are no out-of-the-box storage connectors available, with the exception of Amazon S3.
mallik.koruk11
Level 6
Forum|alt.badge.img+10
Any updates on this topic, got a similar requirement of data transfer from Azure blob storage to Celonis. please let me know if you found any solution. thanks :)
