Hi,I have acess to celonis partner portal but I am not able to acess https://persistent-systems-sandbox.demo.celonis.cloud/ui/login . Please help me to access Sandbox. My email id is manpreet_rekhi@persistent.com, provide instructions
  • Apr 1, 2022 12:13 AM UTC
  • 6 replies
  • 87 views
Hi, I have acess to celonis partner portal but I am not able to acess https://persistent-systems-sandbox.demo.celonis.cloud/ui/login . Please help me to access Sandbox. My email id is manpreet_rekhi@persistent.com, provide instructions
  • Level 5
  • Apr 1, 2022 6:58 AM UTC
HI Manpreet,
In the partner portal, please click on "Explore", button and in the dropdown, you will be able to see "Celonis Sandbox" as one of the option.
Attached is the screenshot,
If you do not see the option (being a first timer), ask the existing sandbox administrator to add your Email and invite you. Then you will be able to see the option in the dropdown.
Regards,
JayB
HI Manpreet,
Regards,
JayB
I am also not able to access sandox.. i went to partner portal and then explore and then celonis sandbox. Its says incorrect user id and pass.. Please help
  • Level 5
  • Apr 6, 2022 9:17 AM UTC
Hi Amit,
I presume your Partner Portal and Sandbox passwords are different. Try resetting your sandbox password when it opens in a new browser. This will help.
Regards,
JayB
Hi Jay, I tried that but not getting reset link. I tried twice. I have also raised a request for this. Can you do something? Thanks, Amit Kumar Singh
  • Level 5
  • Apr 6, 2022 9:29 AM UTC
Hi Amit,
I fear, that should have helped. Have you checked your spam folders?
If still you are not getting any mails, I guess the support team can guide you through.
Regards,
JayB
Thanks for your help. Yes, I checked in spam but no email received.
