Hi,I am facing a problem in "Simulation Configuration Wizard" in Celonis.
  • Jun 14, 2022 1:01 PM UTC
  • 95 views
While filling up the Simulation Parameter "Even Time start", I am getting an error as "The Event time start column is the same as the Event time-end column (as defined in the data model). Please select a different column or leave empty if the start times are not available."
  • Jun 14, 2022 1:14 PM UTC
Hi Asif ,
Please check if the Event time end column value is same as start column Value.
Regards
Ayan
  • Jun 15, 2022 3:39 AM UTC
Hi Asif ,
Regards
Ayan
Hi Ayan,
Actually I have used a flat file with the timestamp for each activity in the activity table. There are no separate time stamps for event start and end values. I have only added one time which is both the start and end time.
  • Aug 2, 2022 8:29 AM UTC
I also facing the problem with the simulation configuration wizard, although I have added two different columns (start time, end time).
Best regards
Tino
