Hi! Has anyone had this error while using the MATCH_PROCESS_REGEX formula?"Internal engine exception. Not able to handle the query request."Any fix or resources to find more about it?
  • Jun 6, 2023 1:08 PM UTC
  • 131 views
lucian.oana11
Level 2
It appears regardless of the given arguments or complexity.
Celonis version: 4.6
Thank you for your help!
gabriel.okaba11
hi @lucian.oana11 ,
as this is the onpremise version, we can check the error directly in our end.
Maybe you hit one of the thresholds?https://help.celonis.de/display/PQL47/Engine+Limitations
Open a SD ticket to get further support on CPM4.6
lucian.oana11
Level 2
hi @lucian.oana11 ,
Hi @gabriel.okaba11,
Many thanks for the reply. It could be that, I'll check them.
Regards,
