Hi folks! I'm trying to create a load balance between my connections since some of them are failing frequently, is there any way where I can see the extractor related to a connection? I think I have some extractors with too many connections
  • Jul 12, 2023 6:22 PM UTC
  • 67 views
andres.naran12
Level 8
Forum|alt.badge.img+10
  • Jul 14, 2023 7:17 AM UTC
Hmmm.... in Admin and settings you can see the list of uplink integrations.... but, at least in my teams, you CAN NOT see the details... like the ip or hostname of the extractor.
If you go to Data Integration, and check in connections, you can see only the data of the connection to the source system.
Neither you get info if you check the extractor logs, no IP, no nothing
So, yes, I am curious also to find that info.
