Hi folks! I know I can use a module to get data from a data model in an action flow, but can I get data from a component in analysis for example an OLAP table in an action flow?
  • Mar 9, 2023 12:58 PM UTC
  • 103 views
andres.naran12
Level 8
Forum|alt.badge.img+10
matt.witty13
Last I asked, there isn't a timetable to import KPIs/Variables/etc. from analyses into action flows. The work around I found is to use 'OLAP to SKILL' on an OLAP table.
image.pngThis button will then create the OLAP Table in a Skill Project. You can then get the pQL from whatever formula you're looking for and copy-paste it into an Action Flow (Query Data module)
