Hi Folks, I have a use case where it would be easiest solution to use COUNT Statement within the FILTER? However it is not possible. Do you have some tips for me? Thanks. B.
  • Jan 19, 2024 10:29 AM UTC
  • 158 views
bunyod.sap
Level 7
marc.v
Level 2
  • Level 2
  • Jan 19, 2024 11:06 AM UTC
Could you give more details about the logic behind the filter? Why is a COUNT needed?
  • Jan 19, 2024 12:21 PM UTC
Unfortunately you cannot filter on a COUNT. You would have to use PU_COUNT instead.
Remember that you can filter on cases only. Using COUNT would convert the result into a KPI (single value). This can be used in tables to show count per case. But not in a filter. For filters you need to explicitly classify which cases need to be filtered. For this use PU_COUNT.
https://docs.celonis.com/en/pull-up-aggregation.html
bunyod.sap
Level 7
  • Level 7
  • Jan 23, 2024 1:54 PM UTC
Thanks for the reaction. Well, what I am trying to create condition to identify the duplicate values. To do so I am concatenating few fields/conditions and simply count them. If all those conditions are met and after counting there will be more than one concatenated value, then it is duplicate for me.
bunyod.sap
Level 7
  • Level 7
  • Jan 23, 2024 2:02 PM UTC
Thanks for the hint. I managed to get what I wanted partly by applying the FILTER PU_COUNT(DOMAIN_TABLE())..etc. condition. Let's me try applying few more ideas if they will somehow help.
