Hi everyone, I'm trying to send a .xlsx file from sharepoint to machine learning workbench.
  • Feb 9, 2024 4:25 PM UTC
  • 6 replies
  • 174 views
andres.naran12
Level 8
Forum|alt.badge.img+10
Unfortunately, we couldn't find any documentation that explains how to send the data from a .xlsx file into a param in the HTTP module, the documentation that Celonis provides only explains how to push data for a CSV file into the datapool directly.
In our case, we want to send the data of the .xlsx file to Machine Learning workbench to create a table that we can send to the data pool, but we don't know how to include the data of this file into the params in the request content from the HTTP Module. Does anyone know how to do that?
matt.witty13
I'm not sure if it would work with security permissions and what not, but you can pass a website link into Pandas' read_excel() function. I currently do that for a public excel file we use for context.
pd.read_excel('[link].xlsx', sheet_name = '[sheet name]')
andres.naran12
Level 8
Hi Matt, thanks for your reply.
Yes I know we can handle this file from Python with Pandas, my concern is related to the action flow itself.
The module "download a File" that exists for SharePoint is able to download a xlsx file. Still, after this file is downloaded I'm not sure how to send this file into a parameter inside the request in the "Make a request" module, I guess I have to transform the data of the file into JSON first.
This is how we have the action flow:
and this is how we have configured the request content:
Soa
matt.witty13
Soa
Ah okay I misunderstood the question. That's a very interesting use case. I've not seen something like this before.
andres.naran12
Level 8
Soa
do you think there is any other alternative to send xlsx files from an action flow to a workbench? unfortunately, I couldn't find any module that allows to get data from an xlxs file and push that data to a data pool directly.
matt.witty13
Soa
I'm not sure. I don't think there's a way to reference the workbench in an action flow. If there is, I'd imagine someone from the Celonis product team would be able to weigh in.
mateusz.dudek14
Level 11
Hi Andreas,
Probably not - I was always using code in ML Workbench and found it working on daily basis reliably for about a year (With single temporary problems) - IMO way to go.
Mateusz Dudek
