Hi everyone,I'm encountering an issue while trying to export data using the SaolaConnector in Celonis, even though I have all the necessary permissions as an admin.
  • Jun 17, 2024 10:04 AM UTC
  • 427 views
nour.mosba
Level 1
The error message states: "Data Export not enabled or missing permissions. Please check permissions or contact Celonis customer support."
As an admin, I have verified that all permissions are correctly set. I'm not sure how to proceed from here. Has anyone encountered a similar issue or can provide some guidance on resolving this error? Any help would be greatly appreciated.
Thank you!
imagethe error output :
PyCelonisPermissionError Traceback (most recent call last)
File ~/.local/lib/python3.8/site-packages/pycelonis/ems/data_integration/data_model.py:430, in DataModel.create_data_export(self, query, export_type, query_environment)
429 try:
--> 430 data_export_transport = IntegrationService.post_api_v1_compute_data_model_id_export_query(
431 self.client, self.id, data_export_request
432 )
433 except PyCelonisPermissionError as e:
File ~/.local/lib/python3.8/site-packages/pycelonis/service/integration/service.py:2311, in IntegrationService.post_api_v1_compute_data_model_id_export_query(client, data_model_id, request_body)
2302 logger.debug(
2303 f"Request: 'POST' -> '/integration/api/v1/compute/{data_model_id}/export/query'",
2304 extra={
2308 },
2309 )
-> 2311 return client.request(
2312 method="POST",
2313 url=f"/integration/api/v1/compute/{data_model_id}/export/query",
2314 request_body=request_body,
2315 parse_json=True,
2316 type_=DataExportStatusResponse,
2317 )
File ~/.local/lib/python3.8/site-packages/pycelonis_core/client/client.py:154, in Client.request(self, method, url, content, data, files, json, params, headers, cookies, timeout, follow_redirects, type_, parse_json, request_body)
153 response = self.client.send(request, follow_redirects=follow_redirects)
--> 154 return self._response_processor.process(response=response, type_=type_, parse_json=parse_json)
File ~/.local/lib/python3.8/site-packages/pycelonis_core/client/response_processor.py:32, in ResponseProcessor.process(self, response, type_, parse_json)
31 """Verifies whether response is valid and parses response body if parse_json=True."""
---> 32 self._verify_response(response)
34 if parse_json:
File ~/.local/lib/python3.8/site-packages/pycelonis_core/client/response_processor.py:42, in ResponseProcessor._verify_response(self, response)
41 message = f"You don't have permission to perform '{response.request.method}' -> '{response.request.url}'."
---> 42 raise PyCelonisPermissionError(message)
44 if response.status_code == 404:
PyCelonisPermissionError: You don't have permission to perform 'POST' -> 'https://estabil-axa-sigorta-c4c.eu-1.celonis.cloud/integration/api/v1/compute/0cd69567-c15f-4dd0-add1-f03c837b6e89/export/query'.
The above exception was the direct cause of the following exception:
PyCelonisDataExportNotEnabledError Traceback (most recent call last)
File ~/.local/lib/python3.8/site-packages/saolapy/saola_connector.py:25, in SaolaConnector.export_data(self, query, distinct, limit, offset)
24 try:
---> 25 exported_data = self._export_data(query)
26 except Exception as e:
File ~/.local/lib/python3.8/site-packages/pycelonis/pql/saola_connector.py:115, in AnalysisSaolaConnector._export_data(self, query)
114 data_query, query_environment = self.analysis._resolve_query(query)
--> 115 return self.data_model._export_data_frame(data_query, query_environment)
File ~/.local/lib/python3.8/site-packages/pycelonis/ems/data_integration/data_model.py:493, in DataModel._export_data_frame(self, query, query_environment)
490 def _export_data_frame(
491 self, query: typing.Union[DataQuery, PQL], query_environment: typing.Optional[QueryEnvironment] = None
492 ) -> pd.DataFrame:
--> 493 data_export = self.create_data_export(query, ExportType.PARQUET, query_environment=query_environment)
495 data_export.wait_for_execution()
File ~/.local/lib/python3.8/site-packages/pycelonis/ems/data_integration/data_model.py:434, in DataModel.create_data_export(self, query, export_type, query_environment)
--> 434 raise PyCelonisDataExportNotEnabledError() from e
436 logger.info("Successfully created data export with id '%s'", data_export_transport.id)
PyCelonisDataExportNotEnabledError: Data Export not enabled or missing permissions. Please check permissions or contact Celonis customer support.
DataExportFailedError Traceback (most recent call last)
Input In [14], in <cell line: 5>()
2 from pycelonis.pql.saola_connector import AnalysisSaolaConnector
4 df = pql.DataFrame.from_pql(query, saola_connector=AnalysisSaolaConnector(data_model, analysis))
----> 5 df.head()
File ~/.local/lib/python3.8/site-packages/saolapy/pandas/data_frame.py:329, in DataFrame.head(self, n)
320 def head(self, n: int = 5) -> pd.DataFrame:
321 """Returns the first n rows based on position as pandas DataFrame.
322
323 Args:
327 First n rows as pandas DataFrame.
328 """
--> 329 return self.to_pandas(limit=n)
File ~/.local/lib/python3.8/site-packages/pycelonis/pql/data_frame.py:44, in DataFrame.to_pandas(self, *args, **kwargs)
42 def to_pandas(self, *args: Any, **kwargs: Any) -> pd.DataFrame:
43 """Exports data from data model."""
---> 44 df = super().to_pandas(*args, **kwargs)
45 internal_tracking_logger.debug(
46 "Exported DataFrame.",
47 extra={"nrows": df.shape[0], "ncolumns": df.shape[1], "tracking_type": "SAOLAPY_EXPORT"},
48 )
49 return df
File ~/.local/lib/python3.8/site-packages/saolapy/pandas/data_frame.py:338, in DataFrame.to_pandas(self, distinct, limit, offset)
335 if self.ncolumns == 0:
336 return pd.DataFrame()
--> 338 exported_data = self.saola_connector.export_data(self.query, distinct=distinct, limit=limit, offset=offset)
339 exported_data = exported_data.set_index(self.index.query_column_names, drop=True)
340 return exported_data
File ~/.local/lib/python3.8/site-packages/saolapy/saola_connector.py:27, in SaolaConnector.export_data(self, query, distinct, limit, offset)
---> 27 raise DataExportFailedError(
28 f"Data export failed for query:\\n{query.queries}\\n\\n{getattr(e, 'message', str(e))}"
29 ) from e
31 if limit is not None:
32 # This is necessary due to LIMIT bug in PQL where an additional row is exported
33 exported_data = exported_data.head(limit)
DataExportFailedError: Data export failed for query:
['TABLE (\\n0 - 1 + RUNNING_TOTAL(1) AS "Index",\\n"CASE_TABLE_TRACKING"."PROVISION_TYPE" AS "CASE_TABLE.PROVISION_TYPE",\\nAVG(CALC_THROUGHPUT(ALL_OCCURRENCE[\\'Process Start\\'] TO ALL_OCCURRENCE[\\'Process End\\'], REMAP_TIMESTAMPS("_CEL_TR_ACTIVITIES_TRACKING"."_EVENTTIME", DAYS))) AS "Total throughput time in days",\\nCOUNT_TABLE("CASE_TABLE_TRACKING") AS "Case count"\\n)\\nORDER BY AVG(CALC_THROUGHPUT(ALL_OCCURRENCE[\\'Process Start\\'] TO ALL_OCCURRENCE[\\'Process End\\'], REMAP_TIMESTAMPS("_CEL_TR_ACTIVITIES_TRACKING"."_EVENTTIME", DAYS))) DESC\\nLIMIT 5;']
matt.witty13
Does the Machine Learning workbench have the permissions necessary? When executing in the ML Workbench, that "user" needs access to Data Integration to execute the query.
imageSearch the name of the Workbench against the permissions of the data pool you're looking to access
nour.mosba
Level 1
  • Level 1
  • Jun 20, 2024 7:26 AM UTC
Hello Matt , Thanks alot for your response!
Yes I double checked just in case and both the workbench and the user have all permissions!
mallik.koruk11
Level 6
Forum|alt.badge.img+10
Hello Mosbah,
For C4C environment, celonis typically doesn't enable exporting data to dataframe sometimes. we need to raise a request to Celonis support.
