Hi everyone!. I have a question. How is possible discriminate a process flow accordin to a specific hour?For example i would like to discriminate a process where a specific activities is done before the 9 a.am respect the other.Thanks
  • Nov 22, 2023 5:14 PM UTC
  • 66 views
Hi everyone!. I have a question. How is possible discriminate a process flow accordin to a specific hour?For example i would like to discriminate a process where a specific activities is done before the 9 a.am respect the other. Thanks
Hi @marina.de.ca
If you are referring to data jobs, you can use schedules for this, as can be found here:
https://docs.celonis.com/en/schedules.html
And if you are referring to Action Flows, you can schedule an Action Flow as well:
https://docs.celonis.com/en/setting-up-action-flows-in-studio.html#UUID-1d733126-0a6b-79aa-0b48-283360ca0006_section-idm4559434719801633458287552052
Many thanks for your understanding.
