Hi Every one,I have a question regarding variable in analysis.
  • Nov 23, 2021 1:42 PM UTC
  • 115 views
when we create a PQL formula including variable . I am unable to use the pql formula with variable in python to extract data or work on data.
please let me know if there is any way to avoid error when variable is used.
Currently I am using formula without variable in it.
gabriel.okaba11
Hi Venkat,
Could elaborate a little further what is the purpose of fetching a variable from python and how does this relate to the PQL formula?
Still, below you can find more info pycelonis library
https://celonis.github.io/pycelonis/reference/pycelonis.celonis_api.process_analytics.analysis.html?highlight=variable#pycelonis.celonis_api.process_analytics.analysis.BaseAnalysisDocument.calculate_variables
Gabriel
  • Level 3
  • Nov 24, 2021 5:24 AM UTC
Hi Venkat,
Gabriel
HI Gabriel,
Thanks for the response, The use case is I want send automated emails to users with excel report having data extracted from table created in analysis.
while extracting data using python data frame there were some error because of columns having saved formula in it or variable.
Thanks,
Venkat N
gabriel.okaba11
Hi Venkat,
Alternatively, you can use Studio functionalities to send emails using data extracted from the Analysis.
celonis.cloud/help/display/CIBC/Send+Email+by+Celonis
I believe this is an easier route to accomplish what you need.
Gabriel
dennis.pflug
Hi all,
we are currently also playing with Pycelonis in our CPM environment and have faced exactly the same issue.
Within the analyses we tried to make use of variables, formulars and often it appears that within a formular variables are used.
With Pycelonis it is not possible to extract a table having columns with formulars containing variables.
Our only solution so far was to switch back from the use of formulars to direclty insert the fomular logic into the table column so that only variables but no formulars are left in the table.
After that the data export via Pycelonis is possible but it makes the use of formulars completely useless.
BR
Dennis
