Hi Celopeers,is there any way or best practice to invite new users with an action flow or anything similar?Is there also any way to download the users list with an action flow as .csv? Many thanks in advance!Jan
  • Jan 17, 2023 12:09 PM UTC
  • 78 views
download user list as .csv
screenshot_download_userlist_as_csv
invite new usersscreenshot_inviteuser
Forum|alt.badge.img+14
  • Level 8
  • Jan 18, 2023 7:13 AM UTC
To Invite a user, you can use the SCIM API - https://XXXXXXXXXX.XXX.celonis.cloud/swagger-ui/index.html?urls.primaryName=SCIM
Similarly, downloading the users can be done using SCIM API or you can use this endpoint - https://XXXXXXXXXX.XXX.celonis.cloud/api/members?includeInternal=true
(ps. provide your domain and cluster in the link above)
And in Action Flow, you can use the HTTP module to call this API and generate csv (CSV module) .
Hope this helps.
