Hi all,is it possible to block another user from deleting my comment in the commenting component for views? And can I block the comment function as long as no specific order number has been selected?Thanks :)
  • Nov 29, 2022 10:17 AM UTC
  • 144 views
sarina.somme
Level 5
Forum|alt.badge.img+11
Hi all, is it possible to block another user from deleting my comment in the commenting component for views? And can I block the comment function as long as no specific order number has been selected? Thanks :)
  • Nov 29, 2022 4:26 PM UTC
I've double checked it, and also deep dive into documentation. There's no such options, the only thing you can do is to suggest it via "Create support ticket" > "Feature request".
Documentation: https://docs.celonis.com/en/comments.html
Mateusz Dudek
sarina.somme
Level 5
  • Level 5
  • Nov 29, 2022 4:35 PM UTC
Thanks!
