Hi all in Analysis I can create a Variable using a PQL statement (A static value). How do i do this in Views?
  • Aug 28, 2024 11:26 AM UTC
  • 186 views
lize.erasm11
Level 6
lize.erasm11
Level 6
  • Level 6
mateusz.dudek14
Level 11
Forum|alt.badge.img+10
The only way is to creating so called "placeholders", unfortunately it's the only way I know to do something similar - standard variables do not allow to use PQL :| .
Example for dynamic name:
Mateusz Dudek
lize.erasm11
Level 6
  • Level 6
  • Aug 29, 2024 8:33 AM UTC
Mmm that is unfortunate, because I need to use this in a graph metrics name and the placeholders are not available there. I wonder why Celonis removed this functionality?
Forum|alt.badge.img+28
Hi @lize.erasm11,
In the legacy views, you can use Javascript to use Variables (and KPIs and thus PQL) values in your components: https://docs.celonis.com/en/legacy-view-variables.html#UUID-3cc2c19d-0a6e-a577-96bd-27e772d7cbc3_id_ViewsVariables-UsingIf-ElseStatementsinfluencedbyVariablesegwhichviewtoshowinembeddedview
As far as I know, this is not (yet) implemented in the enhanced views. Since it is quite an advanced use case, it might be implemented in a later stage, but I have no idea about that.
