Hey there! is it possible to extract the saved variable values in a specific analysis using pycelonis/ML workbench? Any insights on this is appreciated. Thanks in advance!
  • Sep 29, 2021 8:07 AM UTC
  • 34 views
gabriel.okaba11
Hi Pavan,
Short answer is yes (https://celonis.github.io/pycelonis/reference/pycelonis.celonis_api.process_analytics.analysis.html?highlight=variable#pycelonis.celonis_api.process_analytics.analysis.BaseAnalysisDocument.create_variable)
Wondering if it would make more sense for you to use the new functionalities from Studio
celonis.cloud/help/display/CIBC/Set+variable+on+onClick+for+table+component
