Hello, I have build an Action Flow where the result of a query is going in an Gsheet File. I am using the Gsheet action 'Add a row' but after each row i must delay 1 second for each now row. Do you an alternative solution ?
  • Aug 9, 2022 2:23 PM UTC
  • 145 views
Forum|alt.badge.img+2
Could you please try to add Module (tools -> sleep) before the Gsheet module and check if that helps in your scenario.
  • Aug 25, 2022 9:21 AM UTC
Yes it was build like this but i would like erase the 1 second delay to (nearly) none. The volumetry is not high so i would like instantly have the data.
