Hello everyone, I have some problem when I try to use WHERE EXISTS instead of INNER JOIN.
  • Feb 14, 2023 9:38 AM UTC
  • 163 views
I want to complete the elective course Data Integration Case Study - Accounts Payable inside Get Data into the EMS, but I have some problem at the step Transform - Add an Activity: Enter Invoice in SAP.
No problems when I write the code with the INNER JOIN, but I'm not able to run the code whit clause WHERE EXISTS. In attachment you can find both codes. The "WHERE EXISTS" code returns the following error:
Execution error: ERROR: Missing FROM-clause entry for table "BKPF".
Where I'm wrong? I tried to follow the syntax reported in the Get Data into the EMS course but I'm in a dead end.
Thanks in advance.
  • Feb 15, 2023 7:07 AM UTC
The problem is in this line
imageyou are referring to BKPF, but BKPF is inside a subquery (the SELECT inside the where exits), so you can not refer it.
As a thumbrule, WHERE EXISTS is only to select a subset of records based on a relation to another table.
If, as in this case, you need to retrieve any column from the second table, then you need JOIN
HTH
  • Feb 15, 2023 8:56 AM UTC
Thanks a lot, Guillermo.
So, if I understand well, in this case, is better to use the JOIN condition.
  • Feb 15, 2023 9:58 AM UTC
Yes
