Hello,Do you have any experience how to in corporate MSEG & MKPF into O2C data model? Seems that we can join MSEG to MARA through material number. I would be grateful for any hints.Best regards,LukaszBest regards,Lukasz
  • Nov 21, 2022 9:28 AM UTC
  • 173 views
lukasz.luty
Level 4
Forum|alt.badge.img+10
Hello, Do you have any experience how to in corporate MSEG & MKPF into O2C data model? Seems that we can join MSEG to MARA through material number. I would be grateful for any hints. Best regards, Lukasz Best regards, Lukasz
  • Nov 21, 2022 11:27 AM UTC
Hi Łukasz,
I've you've got O2C case I can assume that you've having both VBAP & VBAK tables (one of them probably will be also a case table). It seems in order to connect MKPF/MSEG tables to these, you'll have to create connection like the one proposed below, as just joining it to MARA via MATNR is probably not the best idea:
VBAP-LIPS-LIKP-MKPF-MSEG
VBAP.VBELN=LIPS.VGBEL
LIPS.VGBEL = LIKP.XBLNR
LIKP.VEBLN=MKPF.XBLNR
MKPF.MJAHR=MSEG.MJAHR + MKPF.MBLNR = MSEG.MBLNR (I've readed that inner join between these two tables can be very slow)
Useful links:
https://answers.sap.com/questions/687956/connecting-mseg-to-vbap.html
https://answers.sap.com/questions/1493701/relationship-between-tables-urgent.html
https://answers.sap.com/questions/3046998/join-likp-and-lips-points-will-be-awarded.html
http://sapnet.ru/viewtopic.php?t=4240
Not sure if that was helpful, let us know if that was good approach and how it worked! :)
Mateusz Dudek
lukasz.luty
Level 4
  • Level 4
  • Nov 21, 2022 1:23 PM UTC
Thanks! I will try to test such an approach and share the outcome.
Regards,
Lukasz
lukasz.luty
Level 4
  • Level 4
  • Dec 22, 2022 9:04 AM UTC
Suggested approach works fine. Thanks for your help!
LIPS.VBELN = LIKP.VBELN
LIPS.MANDT = LIKP.MANDT
LIKP.VBELN = MKPF.XBLNR
MKPF.MJAHR = MSEG.MJAHR
MKPF.MANDT = MSEG.MANDT
Regards,
Lukasz
  • Dec 23, 2022 9:40 AM UTC
Hi Lukasz,
Thanks a lot for sharing the outcome, and I'm glad it worked :)
Wishing happy Christmas and fruitfull new year!
Mateusz Dudek
