having issues using PU within another PU as filter
  • Jul 16, 2025 5:52 AM UTC
  • 250 views
bhargav.bhima
Level 2
Forum|alt.badge.img+9
Hi ,
I am trying to use a PU function and use the result as a filter within another PU function.
When i try below PQL it works fine.
PU_LAST( OBJECT, EVENT_LOG,EVENT_LOG NOT IN ( PU_LAST(OBJECT,EVENT_LOG)))
But when i try to add another argument for the ‘not in ‘ it returns nulls . In this example the ‘ABC’ is the additional argument for the ‘not in’
PU_LAST( OBJECT, EVENT_LOG,EVENT_LOG NOT IN ( PU_LAST(OBJECT,EVENT_LOG),’ABC’)) .
have also tried splitting the filter using AND but still same issue persists.
Any insights would be much appreciated.
  • Celonaut
  • Jul 16, 2025 9:17 AM UTC
Hi bhargav,
The PU_LAST function in your PQL is returning nulls because the NOT IN clause can behave unexpectedly when its comparison list contains NULL values. If the inner PU_LAST(OBJECT, EVENT_LOG) evaluates to NULL for any object, the filter EVENT_LOG NOT IN (NULL, 'ABC') will yield an UNKNOWN result for comparisons, which Celonis treats as FALSE, causing those records to be excluded and the outer PU_LAST to potentially return NULL. To fix this, you should use COALESCE to replace any NULL results from the inner PU_LAST with a unique, guaranteed-not-to-exist placeholder string (e.g., '###_NULL_PLACEHOLDER_###') within the NOT IN list, ensuring all elements in the comparison list are non-NULL. Hope it helps, thank you.
bhargav.bhima
Level 2
Hi bhargav,
Hi Navya,
Thanks for your insights .
I tried out unit testing with cases where only non null values will be returned by the inner PU_LAST and still see null values being returned by the outer PU_LAST.
bhargav.bhima
Level 2
Hi ,
What I’m trying to do is essentially pick the last but one non-automated user from the event log and pull it to object level. The previous non-automated user needs to be different from the last non-automated user.
In the sample data shown below the desired output would be JANE.
I’ve tried looping one PU_LAST and using it as filter for another PU_LAST but doesn't seem to be working.
PU_LAST( OBJECT ,  EVENT_LOG , EVENT_LOG NOT IN (PU_LAST( OBJECT, EVENT_LOG,EVENT_LOG NOT IN (‘AUTOMATED’) ))  ,  ’AUTOMATED’).
event log ID
1 JACK
2 JANE
3 JOHN
4 AUTOMATED
5 JOHN
