Having issues connecting to SQL server database for extraction task
  • Feb 8, 2023 5:05 AM UTC
  • 181 views
I am trying to connect my SQL Server to Celonis to extract data from one of the created databases. It's unable to connect with the following error "Test Connection
The connection test failed, please check the Data Connection's configuration and ensure that the system is running: Telnet connection to the host ###### failed. Telnet failure indicates that either host/port combination is incorrect or the extractor is not allowed to access the database due to firewall or access permissions."
I have enabled telnet, and checked host/port settings,. Also, I tested the connection using DBeaver and it works well there.
Has anyone faced a similar kind of situation?
Any help would be highly appreciated.
  • Feb 8, 2023 7:16 AM UTC
Using extractor or directly from Celonis cloud ?
Some ideas:
  • Firewalls or similar between you and the SQLserver ?
  • The SQL server has ACLs to allow connection only from some IP's ?
  • Feb 8, 2023 8:19 PM UTC
Thanks for the response, Guillermo.
Below are the steps I followed:
  1. Login to Celonis EMS environment.
  2. Go to Data Integration.
  3. Create a Data Pool and open it.
  4. Select "Connect to Data Source".
  5. On the Add Data Connection pop-up window, select "Connect to Data Source".
  6. Select categories Cloud and select Database.
  7. On the New Database Data Connection window, provide
    1. Name
    2. Database Type: Microsoft SQL Server (native)
    3. Provide other details such as host, port, username, and password.
    4. Test Connection
  8. At step 7, when I test the connection, it throws the error that I mentioned in the post. I have tried checking all Windows Firewall settings and enabling all other settings.
  • Feb 9, 2023 7:15 AM UTC
Ok, that's a direct connection from the Celonis Cloud. So, from the Internet to your internal servers - your SQL Server.
The most likely explanation is that your SQL server is not reachable from Internet, specifically from Celonis Cloud IP's.
BTW... you said you tested Telnet and Beaver... from which machine/server? Because if it was from your laptop... well it doesn't mean anything as your laptop probably will sit in the internal network and can reach the SQL Server.
HTH
  • Feb 9, 2023 5:42 PM UTC
Thanks for bringing up this internal / same-machine test criterion.
Yes, I was doing all stuff using one machine.
But then, Today I installed DBeaver on another separate machine and tried the same test (providing port, host, and other details).
The connection test passed although the time to connect was higher.
Could it be something else or any workaround to get it connected using Celonis?
