Having issues completing leading steps to connect data import once data connection has succeeded.
  • Feb 27, 2023 2:37 PM UTC
  • 199 views
I'm attempting to create a data connection via .xlsx file on my computer. I created a space and then made the data pool connection alias.
image.pngHowever, once i select "Connect to Data Source" and successfully connect my data, it does not proceed to make the connection.
Can you please help and or instruct me on the correct method to complete the next steps? (See images below)
image.pngimage
Once I selected Esc, the remains equivalent to image one, any help is greatly appreciated.
Thanks!!
Best answer by muthappan.alaga
Goto your data job and create any transformation task to see the table, table name will be Testing_Sheet1image
  • Feb 27, 2023 2:59 PM UTC
The file I am attempting to import is the following:
muthappan.alaga
Level 8
  • Mar 6, 2023 8:58 PM UTC
Thank you for you assistance! Greatly appreciated.
