Have anybody worked on Extracting XLSX file from sharepoint and pushed to celonis using action flow?
  • Jan 20, 2023 2:00 PM UTC
  • 113 views
muthappan.alaga
Level 8
i am able to extract the xlsx file, but i am not sure about the next steps on pushing it to celonis database. i am able to do a csv file using standard template by converting it to json. but how to do xlsx file.
  • Level 0
  • Jan 23, 2023 2:37 AM UTC
Thank you for reaching to us.
In order to be able to assist you further, we would suggest to send an email to servicedesk@celonis.com with detailed description.
We will gladly assist you.
Thank you in advance.
Regards,
Sara
