Have a KPI viz. Average Throughput time and I want to give a selection option for Percentile (50%, 80%, 90% & 98%). How I can do that?
  • Feb 14, 2022 1:33 PM UTC
  • 71 views
Forum|alt.badge.img+7
  • Celonaut
  • Feb 18, 2022 11:32 AM UTC
Hello Rakesh,
To change a value I recommend using a variable (https://help.celonis.cloud/help/display/CIBC/Variables) and use either a dropdown button (https://help.celonis.cloud/help/display/CIBC/Button+Dropdown) to select from a set of static options or a variable input field to allow any entry (https://help.celonis.cloud/help/display/CIBC/Variable+Input).
With that variable set you can then use it as input for the formula QUANTILE (https://help.celonis.cloud/help/display/CIBC/QUANTILE).
Hope this helps you solve the issue.
Pablo
