Has anyone tried to have two case tables in the data model? How can one achieve that?
  • Nov 10, 2021 10:30 AM UTC
  • 101 views
salma.zeped
Level 8
Forum|alt.badge.img+2
Background: for Plant Maintenance we want to use the AUFK and MHIS tables for exploration
  • Nov 10, 2021 2:15 PM UTC
Hi Salma, is there a reason why you are not creating a BI table for AUFK and one for MHIS?
You could add the caseid to your BI table via left join and then connect your tables in the data model via the caseid.
salma.zeped
Level 8
  • Level 8
  • Nov 11, 2021 8:50 AM UTC
Thank you for your reply. What do you mean with BI table? Something like a view?
  • Nov 11, 2021 9:54 AM UTC
Hi Salma, a BI Table is like a table with additional attributes that you can use for your analysis. How to create one? You can just to a select into statement.
For example: Select * into BI_AUFK from AUFK
OR: Select field1, field2 into BI_AUFK from AUFK
If your caseid is not directly in this table and you would like to add it then you can do:
select
caseid,
field1,
field2
into BI_AUFK
from AUFK
left join (the table from where you created the caseid)
I hope that helps.
Amina
gabriel.okaba11
Hi Salma,
You can have two case tables,2 activity tables using what we called "Multi-event Log".
Find more on Celonis MEL on the help page(incl. some videos)
celonis.cloud/help/pages/viewpage.action?pageId=35554007 or search for "Analyze multiple processes" within Help Resourcers.
obs.: even though you are going to use a single Data Model, it will count as 2 Data Models in case you have restrictions of # data models
Gabriel
