Has anyone implemented JD Edwards P2P connector? I need to understand how it works and recomendations coming from real project experience.
  • Jun 15, 2022 3:22 PM UTC
  • 5 replies
  • 239 views
  • Level 0
  • Jun 18, 2022 7:12 PM UTC
Dear Carlos,
Thank you for reaching to us.
In order to be able to assist you further, we would suggest to send an email to servicedesk@celonis.com with detailed description and we will gladly assist you, on this matter.
Thank you in advance.
  • Jun 20, 2022 10:00 AM UTC
Thanks Sara, then I'll go through servicedesk@celonis.com. Regards.
  • Aug 11, 2024 8:29 PM UTC
HI Carlos;
Were you able to make this connection?
Thanks
  • Aug 12, 2024 11:09 AM UTC
Hi Maicol, yes we did. With the base given we built a new connection for P2P and O2C processes .
Carlos,
denis.pede12
Level 7
Hi Carlos, any chance you might still have the table requirements for the P2P process?
Somehow I am not able to find the JDE P2P Connector anymore in the marketplace…
Thanks a lot and have a great start to 2025!
Denis
