Handle nested tables in JSON responses in a custom extractor
  • Dec 22, 2021 6:29 AM UTC
  • 67 views
Hey There!
We are experimenting creating custom extractor to connect to an external application. However the connection is successful and we are able to extract the tables/data, one particular column of a table is extracted as an individual nested table through the JSON response. Is there any way to modify the JSON response and bring them as single table through the extraction? suggestions or reference doc's are most welcomed. Thanks in Advance!
Hi @pavan.bhara13 ,
thank you for reaching out.
Kindly be informed that the Extractor Builder is a low code development tool for data connectivity that allows you to build your own Extractor using a guided interface. Once you’ve created your Extractor with a few clicks, users in your Data Pool will be able to use it as any other native Celonis Extractor.
For more information please check our online help page:  https://help.celonis.cloud/help/display/CIBC/Extractor+Builder
Please let us know if you need further information from our side.
