Fully delete Augmented Attribute
  • Apr 2, 2026 9:50 AM UTC
  • 311 views
thomas.keim
Level 11
Forum|alt.badge.img+5
Hello Community
I played a little bit with augmented attributes and now want to fully delete it.
As you can see in the screenshot I deleted the augmented attributes within the Knowledge Model but the corresponding records still occur. The β€œdelete” button is disabled.
Question: How can I fully delete this unneeded stuff?
Best, Thomas
Β
Β
fabian.wende
Level 6
Hi Thomas,
Β
I’ve got the same problems like you - the partial solution to that problem was, that I created the augmented attribute in another knowledge model - there I could delete it.
But for the other ones, I had to follow this guide:
support.celonis.com
If you still encounter issues deleting the Augmented Tables, please submit a ticket via Celopeers with the following details:
  1. Data Pool ID linked to the Data Model
  2. Data Model ID linked to the Knowledge Model
  3. List of augmentation table that needs to be dropped
  4. Knowledge model key
Β
Fabian
thomas.keim
Level 11
  • Level 11
  • Apr 2, 2026 2:10 PM UTC
Hey ​@fabian.wende
Great, thanks for your support 😊
I will also create an feature request, to delete these tables as self-service.
Using celonis support for such thingsΒ is really annoying.
Best & happy eastern.
Thomas
