Formula does not seem to work properly
  • Sep 27, 2021 1:59 PM UTC
  • 72 views
When i show the same formula (standard throughput time calculation) in an OLAP table vs a number they fail to show the same outcome. Whereas they should.
In the olap table I have applied the formula in combination with a priority dimension. WIth the number I have applied a specific priority as filter. Hence, both the throughput time should be equal. However, they are not.
Any idea what could go wrong?Priority 4 in OLAP should be equal to number
Forum|alt.badge.img+12
Hi @joren.kamer12
Can you please tell us how you are calculating the avg throughput time based on the priority_display_value?
Usually we need minimum two activity or event to calculate the avg throughput time.
I can see some blank value as well for priority_display_value dimension.
Hi Rohit,
Thank you for your reply. I have tried four different methods of calculating the avg throughput time for priority 4 incidents.
Yesterday, three of them yielded the same result and one differed.
However, now I notice a difference. Now it is 2 vs 2.
With method 1&2 I get a different result from method 3 & 4
1:
use the standard formula and apply a selection through attribute selection. Where I navigate to priority_display_value and select '4 - Low'.
Standard formula = AVG(CALC_THROUGHPUT(ALL_OCCURRENCE['Process Start'] TO ALL_OCCURRENCE['Process End'], REMAP_TIMESTAMPS("_CLS_CHANGE_ACTIVITY"."EVENTTIME", DAYS)))
2: use the component filter: FILTER "change_request"."priority_display_value" = '4 - Low' in combination with the same formula
3: use a CASE WHEN statement directly in the formula:
AVG(
  CASE WHEN "change_request"."priority_display_value" = '4 - Low'
  THEN
  ELSE NULL END)
4: Create an olap table. Where dimension = Priority_display_value
and KPI = AVG(CALC_THROUGHPUT(ALL_OCCURRENCE['Process Start'] TO ALL_OCCURRENCE['Process End'], REMAP_TIMESTAMPS("_CLS_CHANGE_ACTIVITY"."EVENTTIME", DAYS)))
Case count is significant: 30,594 for priority 4
