Format Numbers - From 1,00.00 to 1.000,00
  • Apr 4, 2024 1:54 PM UTC
  • 293 views
julia.bauer
Level 9
Hello everyone,
this is probably very easy but I'm lacking the syntax that converts the number format. Can somebody please support me on this?
Thank you!
Best regards
Julia Bauer
Best answer by dennis.pflug
Hi Julia,
have you tried it this way?
This can be used within Action Flows:
formatNumber (number; decimalPOINTS; [decimalSeparator]; [thousandsSeparator])
Returns a number in the requested format. Decimal point is `,` by default, Thousands separator is `.` by default.
formatNumber( 123456789 ; 2 ; , ; . )
= 123.456.789,00
Using Number Format within Analyses / Views I think it is not possible doing this by using the Format feature. Here the thounsandsSeparator is everytime a comma and the decimalSeparator is everytime a dot.
https://www.celopeers.com/s/feed/0D50700001vMS1gCAG?language=en_US
BR
Dennis
dennis.pflug
  • Level 10
  • Answer
  • Apr 4, 2024 3:13 PM UTC
Hi Julia,
= 123.456.789,00
BR
Dennis
julia.bauer
Level 9
  • Level 9
  • Apr 5, 2024 10:37 AM UTC
Thank you Dennis! I'm working on a view and I thought I'm overseeing a syntax but it seems like it does not work yet.
Julia Bauer
