For building a process mining model for a Salesforce object internal to our organization, I'm stuck at an initial phase where our Data Engineer helped connect the SFDC, but was not able to use the Process/variant explorer.
  • Mar 20, 2023 5:04 AM UTC
  • 83 views
Need help troubleshooting what I'm missing, and guidance on the next steps ASAP. TIA
muthappan.alaga
Level 8
Hi Arun,
Which Process from Salesforce you are trying to enable? Is the Extract, Transformation and model Built?
Are you using celonis standard connector which will help to speed up your ETL process?
Thanks
Muthappan
