Flatten OCED Data using perspectives in Celonis Process Sphere
  • Apr 18, 2024 3:06 PM UTC
  • 76 views
Is it possible to select objects and events so that the models correspond to the traditional
Process Mining modells (single case notion..)
If yes what steps are need?
If not where is the limitation?
  • Apr 18, 2024 3:11 PM UTC
Would be grateful if anyone can help.
Thank you!
