Filtering based on ACTIVITY_LAG does not work
  • Oct 3, 2023 12:01 PM UTC
  • 118 views
I am trying to screen the cases where we set order block and immediately release without any activities in the middle. The idea is to calcuate how much time we wasted on those cases.
To do that: In the activities table, I want to partition along column "Change_to" in such a way:
When "Change_from" = 'ZA' (which incdicates release of block)
Then look at the immediate preceding rows: if the column "Change_to" = 'ZA' (indicate set block)
Then calculate the datediff between those rows.
This is my code:
SUM(
CASE WHEN ("_CEL_O2C_ACTIVITIES"."CHANGED_FROM" = 'ZA' AND ACTIVITY_LAG ("_CEL_O2C_ACTIVITIES"."CHANGED_TO", 1) = 'ZA')
 THEN
 DATEDIFF ( MI, ACTIVITY_LAG("_CEL_O2C_ACTIVITIES"."EVENTTIME"),"_CEL_O2C_ACTIVITIES"."EVENTTIME")
END)
It seems that the above code just ignore the bolded part in the casewhen statement. It calculates the datediff even when the direct preceding row does not have "Change to" = 'ZA'.
Any ideas whats wrong with the code?
Best answer by Anonymous
use of coalesce function will solve the issue for you, as not all the activity have value in changed from and changed to column, it will take last null value.
please use the below code, it should solve the problem for you
SUM(
CASE WHEN ("_CEL_O2C_ACTIVITIES"."CHANGED_FROM" = 'ZA' AND ACTIVITY_LAG (COALESCE("_CEL_O2C_ACTIVITIES"."CHANGED_TO",''), 1) = 'ZA')
 THEN
END)
abhishek.chatu14
This should work not sure what is the issue here try something like this
SUM(
THEN
CASE WHEN ACTIVITY_LAG ("_CEL_O2C_ACTIVITIES"."CHANGED_TO", 1) = 'ZA')
THEN
END END)
  • Oct 4, 2023 8:26 AM UTC
SUM(
THEN
THEN
END END)
Hi Abhishek,
I did try this. The code behaves the same way, not filtering the value requested in ACTIVITY_LAG statement.
  • Answer
  • Oct 9, 2023 5:40 AM UTC
SUM(
 THEN
END)
  • Oct 9, 2023 8:54 AM UTC
SUM(
 THEN
END)
@Devesh: Thank you! You are right. The issue with my code rooted from the data. And your code works perfectly 👍
