Filterin multiple input into a variable
  • Jul 25, 2022 2:36 PM UTC
  • 135 views
I have a button dropdown, where I've different inputs like:
EINDT
SLFDT
MENGE
NETPR
Separator : ,
I'm wrapping with:
start = '
end = '
My variable I'm writing into is changeFields
So I did a KPI where I'm using this case when:
CASE WHEN <%=ChangedFields%> = 'Lieferdatum (EINDT)' THEN 'EINDT'
WHEN <%=ChangedFields%> = 'Stat. Datum (SLFDT)' THEN 'SLFDT'
WHEN <%=ChangedFields%> = 'Preisaenderung (NETPR)' THEN 'NETPR'
WHEN <%=ChangedFields%> = 'Mengenaenderung (MENGE)' THEN 'MENGE'
THe problem is, when I'm using more than 1 input my CASE WHEN state the project doesn't work.
I tried it like:
WHEN <%=ChangedFields%> = 'Lieferdatum (EINDT),Stat. Datum (SLFDT)' THEN 'EINDT,SLFDT'
But this idea doesn't work. I also tried to do it with logic gates.
Does anyone have an idea how I can filter multiple inputs and check it in a case when function?
Best answer by Anonymous
Hi @1460047082 ,
Try by using 'LIKE' instead of the '=' sign.
Also for your case 'IN' or 'IN_LIKE' might work.
  • Answer
  • Jul 25, 2022 3:32 PM UTC
Hi @1460047082 ,
