FILTER some data only when a condition is true.
  • Jun 11, 2024 8:42 PM UTC
  • 5 replies
  • 191 views
I want to filter based on a condition like this:
FILTER Color = 'blue' WHEN Shape = 'square'.
I'm having trouble creating a formula like this because what I have tried is filtering all instances where Color = 'blue', but I want to filter only for blue color when the shape is square.
I think this should be something very easy to do, but I'm having trouble.
Thanks in advance :)
  • Jun 12, 2024 5:07 AM UTC
I am not completely sure if I understand your question correctly, this could be a simple OR, i.e.
FILTER Color='blue' OR Shape !='square'; (this would filter out all squares that are not blue but leave all other shapes in). For more elaborate statements you can also use
FILTER (
CASE
WHEN shape='square' AND color ='blue' THEN 1
WHEN shape='round' THEN 0
WHEN shape='triangle' AND color='red' THEN 1
END) = 1;
BR
Stephanie
florian.mrkvi
Level 7
Forum|alt.badge.img+3
" I want to filter only for blue color when the shape is square"
That would be done like this: FILTER Color = 'blue' AND Shape = 'square';
BR Florian
  • Jun 12, 2024 4:13 PM UTC
Hi Stephanie and Florian,
I have tried using the AND condition but is filtering both conditions. For this example: FILTER Color = 'blue' AND Shape = 'square'; it's filtering all the color=blue and shape=square. But it should only filter blue when shape is square.
Let's take as example the following table:
image.pngThe desired output is the following:
image.pngWhat I'm getting with FILTER Color = 'blue' AND Shape = 'square':
Thanks,
Julio
  • Jun 12, 2024 4:57 PM UTC
Hi Julio,
according to your example you have a wrong understanding of what FILTER does. It is positive, i.e. FILTER shape='square' will filter for squares only and triangle will be EXCLUDED. In the above example
FILTER shape != 'square' OR color !='blue' will result in the desired output.
BR
Stephanie
dxb.miner
Level 5
  • Level 5
  • Oct 25, 2024 10:40 AM UTC
@julio.bolan12
Try below formula ,
FILTER shape != 'square' OR ( shape = 'square' AND  color !='blue' )
