Filter on cases where LAST entry (document) meets specific conditions
  • Feb 29, 2024 5:36 PM UTC
  • 104 views
felix.keite12
Level 2
Dear community,
I need your help with pql. I want to create a table which should display only the LAST document for each case (based on Document creation date). The documents table is directly linked to the casetable.
I tried with component filter but syntax error is appearing:
FILTER PU_LAST ( CaseTable.CaseID, Documents.Technical_ID [, ORDER BY Documents.CreationDate DESC)
Based on the last entry/document for each case I have additional filterings like "documents.type" = 'A' etc. - but even when deleting the further condtions the querry is not working.
Do you have an idea? Thanks in advance!
Best Felix
Sverre Klein
Forum|alt.badge.img+13
Hi @felix.keite12,
I'm not a king in PU functions so bear with me here. I'm still learning 😉
I don't think you should use a filter on your table, but an KPI. Try this one.
PU_LAST ("CaseTable", "Documents"."Technical_ID", "Documents"."Type" = 'A', ORDER BY Documents.CreationDate DESC)
The filter expression "Documents"."Type" = 'A' can be changed or deleted if you want!
I have tried to replicate it in my sandbox, this is what I got.
Case ID is from my Case Table. (dimension)
Last Activity is the last activity that occurred in that case (KPI). --> PQL:
PU_LAST ("CASE_TABLE_HUBSPOT", "ACTIVITIES_TABLE_HUBSPOT"."ACTIVITY_NAME", ORDER BY "ACTIVITIES_TABLE_HUBSPOT"."EVENT_TIME" DESC)
Hopefully this helped you out.
Sverre Klein
dennis.pflug
the FILTER doesn't work as the filter condition doesn't know what to filter.
The result for your PU_LAST function will be the Technical_ID per Case.
Let say one of your Technical_IDs would be 12345 in this case your filter looks like this
FILTER '12345'
So for use cases where you need to add PU_ Functions into a Filter you need to have condition like
FILTER PU_LAST(CASE, Technical_ID) = '12345'
which would result in FILTER 12345 = 12345 for some cases and this will give you a result at the end.
BR
Dennis
