Filter in Case explorer
  • Sep 30, 2021 11:08 AM UTC
  • 61 views
I have crated a basic analysis for my team with only 1 sheet as case explorer.
In the case explorer i want to hide few columns and publish the analysis. I don't want to show few columns to the team. Is there any functionality to hide columns in case explorer and publish?
Regards,
Ashok
Forum|alt.badge.img+12
Hi @chanti.p
I guess as of now we don't have that hide column functionalities in case explorer.
As a workaround what you can do is try to create an OLAP table separately with the requisite column which you want to show to your team.
In the OLAP table you will get an option to hide the unwanted column as well.
Hope it helps.
Happy Learning.
  • Level 3
  • Sep 30, 2021 11:38 AM UTC
Thanks for your quick response Rohit.
I tried the same, created an OLAP table with only required columns. But thought of check with this big forum as i might not aware of such functionality if available.
Regards,
Chanti
