Filter a KPI - PQL struggles
  • Apr 22, 2024 9:51 AM UTC
  • 286 views
Lovise Hellner
Hi team,
I want to create a KPI to measure the proportion of items with missing routes. BUT I want the scope of my data to be filtered only on specific order types.
I could add a filter on the component, but to make sure the KPI is always measured the same everywhere, I want to have the filter within the KPI calculation.
I understand the below formula is not correct ('The aggregation function SUM cannot be used together with a dimension function input.') but I am struggling to find the solution. Any suggestion ?
Thanks heaps
CASE WHEN "VBAK"."AUART" IN ('ZCS','ZECH','ZEDI','ZCSG','ZEDC')
THEN SUM (CASE WHEN "VBAP"."ROUTE" IS NULL THEN 1 ELSE NULL END)
/ COUNT_TABLE ( "VBAP" )
ELSE NULL END
Best answer by dennis.pflug
Ok than something like this?
SUM(CASE WHEN "VBAK"."AUART" IN ('ZCS','ZECH','ZEDI','ZCSG','ZEDC') AND ISNULL("VBAP"."ROUTE") = 1 THEN 1.0 ELSE 0.0 END)
SUM(CASE WHEN "VBAK"."AUART" IN ('ZCS','ZECH','ZEDI','ZCSG','ZEDC') THEN 1.0 ELSE 0.0 END)
dennis.pflug
Hi Lovise,
please try it like this:
BR
Dennis
Lovise Hellner
  • Community MVP
  • Apr 22, 2024 11:30 AM UTC
thanks for taking the time to respond @dennis.pflug
the formula technically works but it does not match what I want to achieve.
my filter should apply to the entire formula (the dividend and the divisor).
In other words:
number of items when route is null and so type = A, B, C
number of items when so type = A, B, C
cheers
dennis.pflug
  • Level 10
  • Answer
  • Apr 22, 2024 2:37 PM UTC
Lovise Hellner
  • Community MVP
  • Apr 22, 2024 3:14 PM UTC
yes ! it works !!
thank you @dennis.pflug
