Filter a KPI
  • Dec 2, 2021 5:05 PM UTC
  • 7 replies
  • 182 views
We am trying to filter an OLAP table with a KPI or from the same table. In general we want to exclude from the analysis the rows of that OLAP Table that do not match with a condition (given by a KPI, a calculus etc..).
*In the example, we would like to take values 5 and 6 from the column "COUNT(BKPF)"
Capture
If anoyone have the same trouble or could help me for that I would appreciate it. Than you in advance.
  • Dec 2, 2021 5:19 PM UTC
Hi @andrea.lópez, have you tried to use a component filter in the olap table wit the requested pql, if you want to exclude the 5 and 6, then the would be FILTER COUNT(BKPF) NOT IN (5,6).
1) Right click on component (edit mode)
image2) insert the filter condition in the 'Load script' part
Hope it helps
  • Dec 2, 2021 5:24 PM UTC
Hi, Javier.
Thank you for your answer but that filter doesn't work in my case. Capture1Capture
Also, in my case it isn't a general filter because I want to filter rows, not the general table.
Thank you again
  • Dec 2, 2021 5:33 PM UTC
oops, yes sorry 😶 , aggregations can not be use in filter statements, probably the PU_COUNT() will make it, what do you mean with filtering rows and not the general table?, do you mean a dynamic filter like the search ?
  • Apr 8, 2022 1:45 PM UTC
Hi Guys,
I am interested in the same topic, any update?
How can you filter based on a column in OLAP table? For ex. if I have 1 table with customers that meet a criteria and want to use the result to dynamically query another OLAP table.
Thanks for help
Dessy
  • Nov 18, 2022 7:07 PM UTC
Actually it is possible to apply a filter within a KPI!
Here an example to count all cases if failure category is D:
SUM(
CASE WHEN "Case table"."FAILURE CATEGORY" = 'D'
  THEN
    1.0
  ELSE
    0.0
  • Dec 5, 2022 5:44 PM UTC
Hi friends, could you please share if it has been resolved? I have the same case and I don't know how I can filter a table by a KPI that I have created 😭
  • Dec 5, 2022 6:45 PM UTC
Hi again,
Could you help me tell me how I can apply a filter with a KPI to an OLAP table (Component filter -> load script), Sheet (Setting -> Load script) or Number (Single KPI Components)?
I explain:
I have created a KPI that returns OK, KO or WARNING as a result. I want it to show me only the KOs. How can I do it?
For example, in OLAP table. Here I want it to show me only the KOs:
This is how I create the KPI:
CASE WHEN
(SUM (CASE WHEN "VBFA"."VBTYP_N" = 'J'
THEN 1
ELSE 0
END)) = 0
THEN 'WARNING'
WHEN (SUM (CASE WHEN "VBFA"."VBTYP_N" = 'J'
THEN 1
ELSE 0
END)) =
(SUM (CASE WHEN "VBFA"."VBTYP_N" = 'M'
THEN 1
ELSE 0
END))
THEN 'OK'
ELSE 'KO'
For example, in number (Single KPI Components)
imageI want to be able to later separate the total for each result into containers
Basically I want to add the KO, OK and WARNING
Thank you very much in advance.
Joel Luis
