Fetch more than 100k rows in action flow to create CSV
  • Jan 30, 2026 9:23 AM UTC
  • 184 views
nishad.fasge11
Level 2
Hello, I need to pull around 1 million records from a table in DM and create CSV for a weekly automated report. As of now I am using GET_ROWS module but it has limitation of 100K records. Can someone suggest the most optimal way to handle or bypass this constraint and create the csv?
carlos.taleg11
Level 9
Forum|alt.badge.img+10
I suggest using Python for scenarios involving large volumes of data, since action flows are subject to performance and capacity limitations.
Regards,
Carlos
