Feature Request: Target Throughput Time as part of the Process Model for Conformance Checker
  • Jul 30, 2021 12:10 PM UTC
  • 66 views
Hi team!
We've figured out a use case where modeling the target Business Process via BPMN in Celonis may not be enough. We'd also want to:
  1. Be able to indicate target throughput times for specific activities while building/uploading Process Model in the Conformance Checker
  2. Be able to run the comparison of the target Process Model against the actual process taking into account indicated throughput time, so that the user doesn't need to enter Targets as constants and build the OLAP table to compare against them using PQL.
gabriel.okaba11
Hi Mariana,
You can create custom KPIs by clicking on the left tab on the conformance checker (even reuse your KPI formulas).
Celonis is constantly enhancing its product, recently Celonis released aCustom dimension for Conformance Checker
You can now provide a custom dimension in the conformance checker to measure conformance of a column other than the default activity column.Check out the release notes for more info:
https://help.celonis.cloud/help/display/CIBC/PA+1.60
Reach out if you have any questions or feedback. Thank you!
If the custom KPI is not sufficient, feel free to reach out to servicedesk@celonis.com and request a product enhancement
Gabriel
