facing issue while creating dropdown
  • Feb 24, 2025 6:37 AM UTC
  • 5 replies
  • 233 views
kiranmayi.kadim
Level 2
Forum|alt.badge.img+7
Hi Team,
I am facing issue while creating dropdown, I have used below PQL Query
CASE WHEN
RUNNING_TOTAL(SUM("PO_LINE_ITEM"."NET_VALUE_LINE_ITEM_IN_REPORTING_CURRENCY"))
GLOBAL(SUM("PO_LINE_ITEM"."NET_VALUE_LINE_ITEM_IN_REPORTING_CURRENCY")) <= 0.8
 THEN 'Top 20% Vendors'
 ELSE 'Remaining Vendors'
while using this query in the dropdown i am getting only one option either 'Top 20% Vendors' or  'Remaining Vendors' but i want both the options in the dropdown. So pls kindly revert ASAP.
Thanks,
Kiranmayi
Forum|alt.badge.img+2
Hi Kiranmayi,
Try adding “OVER (PARTITION BY "PO_LINE_ITEM"."VENDOR")”
it will ensure that the Running_total is calculated per vendor rather than globally.
kiranmayi.kadim
Level 2
Hi Team,
could you help me out for the PQL query ?
CASE
    WHEN
kiranmayi.kadim
Level 2
Hi Team,
I have used above pql query which was given by you. But it is showing as attached. Running total is not working in button dropdown.
kiranmayi.kadim
Level 2
Hi Team,
Please help me on above mentioned
Thanks,
Kiranmayi
