Extraction Server: "Internal error" when changing connection prerequisites
  • Nov 23, 2023 9:20 AM UTC
  • 182 views
jens.rohde12
Level 0
Hi, we have an on-prem extraction server with a working uplink connection and working SAP/JDBC connections running.
When we try adding a new DB connection, we receive this error message:
"Connection test failed, please check the Data Connection's configuration and ensure that the system is running: Extractor responded with an internal error"
This is hard to troubleshoot, since the service is definitely running and working. Any idea on what might have gone wrong here?
I can rule out a port error, as I can force this one by changing the port of an existing DB-connection.
Thanks for your help in advance!
jan.vajse12
Level 7
Forum|alt.badge.img+2
  • Level 7
  • Nov 23, 2023 10:22 AM UTC
Hi Jens,
we are experiencing exactly the same issue with our JDBC extractor. Since two weeks it shows this error message. On our infrastructure site seems all right, we checked it with our IT.
To resolve the error I contacted our Celonis Key Account and he promised to bring their technical expert on board. I would suggest you to get in touch with someone from Celonis via your contact person as well.
Cross-fingers!
Regard
Jan
