Extraction fails with Cannot create PoolableConnectionFactory (Database 'X-X-X-X-X-X' is unavailable. It is undergoing LOAD TRANSACTION
  • Sep 3, 2021 4:29 AM UTC
  • 54 views
Forum|alt.badge.img+7
Hi everyone,
I have a connection to a Sybase ASE database and extracts configured that work correctly, however on certain occasions these fail with the following error: "The data source configuration is invalid Unexpected error when creating database connection: Cannot create PoolableConnectionFactory (Database 'X-X-X-X-X-X' is unavailable. It is undergoing LOAD TRANSACTION."
My client has declared that this data source is a replica of the production database, which is updated every 5 minutes, during this update that is carried out at the transactional level, the connections are blocked, but this lasts only a few microseconds.
I would like your feeedback, to know alternatives that can help me, so that the configured extractions can support this scenario, since the whole process of updating and creating the Celonis data model stops.
I unsuccessfully searched for some configuration that would allow me automatically failed extracts to have the ability to retry to run.
I appreciate your help in advance.
